ft413;1155959 said:this problem just started happing recently. when the turbo spools up and i shift or just let off the gas my turbo will make a fluttering noise. i have not done anything to the car except k&p filter and custom exsuats. any help would be great thank you
vdragonmpc;1155963 said:The K&N makes your turbo intake a LOT louder to you so you may be noticing the change from that however: What Blow off valve are you using. It could be going bad.
V
forcefedsupra;1155994 said:werd/\
Poodles;1156013 said:He said it didn't happen after he put the intake on.
Double check the lines to the stock BOV. Did you do anything to the car before this happened?
ft413;1156158 said:i dont think its the bov i just checked it and i couldnt blow threw it. all the hoses are new that are going to it. any other ideas?
SideWinderGX;1156281 said:Wait, this is backwards.
The link to the SUPRAS.COM webpage explaining the saab BOV says that if you CAN blow through it, its broken.
You guys are saying since he CANNOT blow through it, its broken.
Which one is it?
Mine makes a fluttering noise when I'm at peak boost and i let off the accelerator, much like an SSQV or any BOV on an MKIV would sound. I also have an HKS filter, and it never made that sound before.
Nothing is broken yet, although I might get a new BOV anyways.
Poodles;1156359 said:Nobody has said that... Specificly I'd mentioned the lines to the BOV as if it doesn't have a good vaccum source it won't operate propely...
87M-GTE;1156179 said:Yeah thats compressor surge. your bov is not opening and that pressure is being forced back through the system and is trying to get out, and the only place for it to escape is back through your turbo...
Which one is it?
