Couple of days now I've been hearing a squeaking noise coming from under my hood. It's weird, it only squeaks on initial startup for about a second. Then I would drive and it would be fine, no strange noises. Then all of a sudden I would hear my clutch fan make a very heavy noise and the squeak will be continuous from 4k - 7k rpm. The Rpm's below 4k I would not hear a squeak, but clutch fan sounds ridiculously loud
. Then I would stop the car and turn it on later and it would drive normally and come back randomly.
I changed my serp. Belt yesterday because it seemed obvious. Problem seemed to have went away yesterday. But then on my way to school the heavy clutch fan noise came back and then as soon as I hit 4k rpm the squeak came back!
It's a very annoying problem. What do you guys think it could be? Maybe the alternator bearing?
It's weird because my clutch fan will start to make a very heavy noise, and that's the signal that I listen for when I knw it's going to start squeaking in the upper Rpm's...I'll start it back up when I leave class and see what happens
