Weird brake problem. Scared to drive car now.
DegreE
500
Memphis & Miami
So for the past week, I've been getting a buzzing noise from the brake booster when I apply the brakes for the first time since starting the engine.
And while I get this buzzing sound, the pedal feels stuck and wont go down further. Meaning the brakes will not apply and stop the car.
The buzzing sound happens as I have my foot pressed on the brake pedal and only lasts for a couple seconds.
But it only happens when I first start the engine. After that it will do it acouple times then it goes away and the car brakes like normal.
I tried bleeding the system and it still does it.
I'm afraid I need a new brake booster. has anybody else herd of this before?
DegreE
500
Memphis & Miami
Any idea on how much a new brake booster goes for?
Is it something I can get at Napa or Autozone, or should I start searching Ebay and Junkyards?
Kckazdude
1,239
Memphis, TN
Call me tommorrow. I have one on my parts car you can try out.
DegreE
500
Memphis & Miami
Sweet, will do.
Buddafucco;974375 said:
Check your vacuum hose and check valve at the booster first.
I double checked all my vac hoses. They're all good. My idle is perfect. No hissing sounds under the hood.
DegreE
500
Memphis & Miami
I just checked EBay.
$30-$40 for a used one. + $12-$15 for shipping.
Anybody have any tips on changing this thing out? The dash doesn't have to come out does it?
OneJArpus
2,798
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=BR&P=20
Check that out. (PS I do not think you have to remove dash, just a panel from below thats all)
