89 7MGTE, stock except exhaust + FMIC. Installed in a 1989 4runner. Has about 10 miles and an hour on a rebuilt engine. I made new strong grounds for the head and the ignitor, and they measure fine. It ran beautiful (at 50F to 80F ambient), with no codes, and then I did the following before I was going to drive it over an hour to new garage for finishing touches on the chassis:
Weak spark: With the ignition "on" and a spark plug out of the cylinder, my #1 plug seems to spark erratically when I turn the CPS with the engine on TDC for #1. It will "click" and make a little puff of smoke instead of sparking, and then it will spark the other half of the time. Without a plug in the high tension wire, it will easily arc a half an inch. I can only get the system to fire (plug or not) about half of the time the CPS passes through the point when it should tell the coil to fire. It seems to not fire at all if I move the CPS slowly.
When I try to start the engine, it fires a little bit, and the tach registers. Sometimes it starts and immediately dies.
My plugs are not very old at all. Can they foul this quickly? The temp is now 30F ambient. I also have high tension wires (FSM term for spark plug wires) of unknown age. They are flexible and have never given me trouble before. Any ideas?
Fixed the heater motor (removed ECU for access)
R+R CPS (fixing leaky gasket)
Replaced leaking heater core line (lowered engine 2" for access room)
No-start condition. Fuel and spark both present. Cleaned wet (from gas) spark plugs with a propane torch. No start. Re-installed CPS and the beast fired right up, idled great, revved great (at 28F ambient). shut down.
Tried to restart. Fuse blew for dome light. No start. Code 11.
Diagnosed very bizzare electrical problem to a weak battery ground connection. Cleared code. Still no start, still no codes.
