927mgtepat said:Just wondering if any one has any good ideas on how to mount a fuel cell in the supra?
Thanks very much, My dad found this online what do you think?Slow66 said:Since the Supra is a "hatchback" with no rear firewall, the only way to legally do it (for racign anyways) is to mount it UNDER the floor, with an access door (kinda like this one... http://www.jegs.com/webapp/wcs/stor...atalogId=10002&storeId=10001&categoryId=13145 ) to get at the filler cap.
So essentially it will involve cutting out the spare tire well, making a flat floor, and securign the cell from the bottom with straps. Kinda a pain in the ass, but worth it for the piece of mind.
927mgtepat said:
i plan on using steel so i can weld it right to the rear floor panSlow66 said:Pretty much exactly what you gotta do if you want to do a box. Looks well done and above all, is the safe way to do it. You could also weld the sparetirewell with flat steel and do straps out of 1x1 steel, almost like a fuel cell "cage" and tie it into the rear "framerails". There are a few ways to do it, but as long as the cell is isolated from the drivers compartment, its all good. Also, be sure to double check the NHRA rules for appropriate thickness of the material. If you use AL, it will have to be thicker than sheetmetal, that is of course if you want to comply with track rules of course.
