jetjock said:Something is wrong there. If you're lean Vf should be showing 5 volts. Makes me wonder if you're even in closed loop at idle. You can't use Vf to check at idle though. You'll need to measure the OX terminal instead. Or use Vf and crack the throttle just enough to open the IDL contact.
I hooked up to the OX terminal and grounded terminal. I'm guessing that is the proper way to test OX?
To my understanding,
0.00 MV is lean
450 MV would be Stoich
800 MV would be rich
It's measuring 420 MV at idle, fluctuates from 400 - 440, but stays at 420 MV more, less.
