water temp at 230F with the AC on, is normal?
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
Poodles said:
usually when a fan clutch goes it's also nice and greasy in the center (if that seal went out like mine did)
Get it over with. Go to NAPA, get a block test kit and do the do. This way you won't torture yourself wondering if you have a BHG.
In my experience these kits will find even a slightly leaky HG, and are as bankable as money.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Yep...the under tray keeps air flowing through the rad. Without it, air will take the path of least resistance and that is not through your radiator ;)
tissimo
Stock is boring :(
Melbourne, FL
guess i'll install it.. I've been putting it off as I didn't want to distort it around my intercooler, but if itll help i'm all for it :)
CarlosPTR210
435
Calexico,CA
www.ptr.com.mx
Poodles said:
fan clutch helps too :p
got any pics of this fan clutch you got at kragen?
Ups let me pick up the box from the garbage jojojojojo.
Also a big diferent is the sound of the fan, before I don't hear it, Now I can hear it! WOW jajajaja.,
I will post the brand and part number!.
By the way, I also have the undertray, I'll try to install this weekend, becasue I have a new turbo set up so I'll see if I can install it or need some modification:sarcasm:
If i don't fit my undertray I see + 5>8c temps here cruising at Highway speeds and while in my case it's not even close to running hot in a car with marginal cooling ie: (Blocked rad, debris in the AC Con, dirty scaled block) it would be enough to tip you into overheating...
mkIIIman089
Ohio
I have to disagree on that marginal cooling bit... I think its more then robust enough to do what its meant to.
That is strictly speaking water, oil is a little different story. LOL.
CarlosPTR210
435
Calexico,CA
www.ptr.com.mx
Here are some pics:
USMW Professional Series:
Stock No. 22085
Heavy Duty Fan Clutch US MotorWorks
General aplication:
Cresida 2.6 1980
Cressida 2.8 88-81
Cressida 3.0 92-89
Supra 2.8 85-81
Supra 3.0 92-86
tissimo
Stock is boring :(
Melbourne, FL
sweet.. I'm ~ 210f on the highway and would like to get it to ~ 200f and i'd be happy. a bit high, but for electric fans, cant ask for much, hahah..
Does that waterwetter stuff work at all? if i can get 2-5*f from that it would be worth it as well..
mkIIIman089
Ohio
Works best with straight water, and there have been reports of it gelling up with coolant. Who knows what else was happening in those cases.
never had an issue with em gelling with coolant
they work best with straight water but straight water works better than coolant and water as well, it's about protecting the system as well...
