water pump installation questions??
suprafanatic
1,607
Greenwood, IN
so i ordered a new water pump for the supra,, mine started leaking. should be here tomorow.. anything important i need to know about installing the new water pump? i'v never done it before so i dont know what to expect. any help/ advice is greatly appreciated, thanks!
follow the TSRM...
the bolts and studs have different torque settings, overtorque and you break bolts, undertorque and it leaks...
make sure you clean the gasket surface well, and I flushed a ton of crap out of my block while I was there...
