toy fanatic78;1190868 said:If you're gonna correct my terminology could you also answer my question, what purpose does the heater control valve serve? Doesn't it restrict flow to the heater core when the temp is turned down on the climate control so as not to have hot air emanating from your dash?
exactly, so what other time when using the climate control would this be helpful? Hint: think of the buttons that are actually there :icon_bigg
Also, the valve itself isn't really variable, its on/off from how i understand it. The variation in temps is a combination of hot air and ambient air from outside or inside depending on selection.
