hmm I shouldn't have taken the time to type that, I found the link. Here is the direct copy from supra forums:
EDIT: Woops! deabionni beat me to it
After having one servere issue arise(we are working to correct it) I must strongly advise the following points.
1: It is best to do this mod with the transmission out of the car, the time saved by just pulling it will payoff on assembly
2: Get a new gasket, they are VERY sensitive to dust and such and can distort and bleed pressure
3: DO NOT OVER TOURQUE THE BOLTS. This is CRUICIAL you can warp the valve body or the transmission case when you do this. The spec is around INCH LBS, No airtools allowed for the valve body!
4: Do not mix your bolts up, they go in certain places.
The issue that has arrisen is a car shifting into reverse when it should go into overdrive, and it appears to be a pressure bleedoff issue, once we have that exact cause located, I will post it, and ways to avoid it.
Remove transmission(my preference)
Remove the transmission pan bolts, I marked most of them, you can figure it out...
Remove the filter with the three marked bolts. Also there are two metal tubes, I already had them out so I drew them in, gently pry back and forth and they will come out
The fun part, my recommendation is do not take the bolts out of the valve body, they are specific on their location.
Completely loosen the brown arrows, loose till there is slack on the bracket for the purple arrow, and remove electrical connectors marked by blue. Before you can remove the valve body, you must disconnect the kick down cable, see next picture to see the bottom side of it
This is what everything looks like once you get the valve body off, The two "things" marked are accumulators, those two are the only ones we are concerned with at this time
A close up of the accumulators
This is the first accumulator stretched out, the trick to getting them out is to push them all the way down and let them pop up... only way I can get them out.(this is the b-2 accumulator 1-2)
This is the bottom side of the accumulator(the one without the solid rod, that would be put in first going back in) This is where you want to place your shims, you want the shims to be about 1/3 of the spring travel, unless you don't care about you neck and you're tires breaking loose every shift.
Make 100% sure that you do not block this port, if you do, you're screwed.
This is the c-2 accumulator 2-3 see above for details
inside c-2 place shims as above
Again, don't block this port
This is just a reference picture, of how far the travel is, but you'll be figuring that out on you're own.
again reference, this is the outside of the tranny, to from the right, b-2,c-2, then the kick down cable.
Final reference, on reassembly, make sure this is how the shift lever looks, otherwise it won't work.. =)
Final note, the easiest way of locking the kick down full open is to cut the cable(with valve body and transmission fully together) and then lock it with a cable lock or other vising device, unless you want to build a wedge to put in when the valve body is out, all a matter of preference.
Not too descriptive, but I hope this at least will give you all an idea of where to start with when upgrading a a340. Also, I don't see much need of a upgraded valve body, from what Ive researched, they are rarely more then what you can do you're self here, or slightly enlarged passages, not worth the money to me.
