I think he was talking about fuel (rpm) cut from a shorted IDL. If so he is correct. In fact, for an "I'm no TPS expert", the post was pretty damn good...
ben1984j;1581021 said:Haha. Thanks JJ. Yeah, that was the fuel cut I was talking about...I didn't know that IDL was used for deceleration fuel cut as Nick said.
Nick M;1581025 said:Have you seen the autoshop101 website? It has most of the TCCS OBD and OBDII EFI technical articles Toyota has published for technicians. Nearly everthing is there.
Ok, let's put it this way.. For me there is no noticeable performance change with having knock sensor error. I've never had this GTE engine running without this error, and at the moment there is no fuel cuts, it boosts good etc.. but sure it's probably as you say effecting the amount of performance. However, it doesn't make the engine go anything then smooth.. so for me I'm happy with that. lolshaeff;1580892 said:LOL @ thinking the code 52 has no effect on performance. :nono:
Fix the code. :nono:
In all honesty, I bet you'll be amazed how much better your car will run. It's like night and day.
scotty;1581263 said:Ok, let's put it this way.. For me there is no noticeable performance change with having knock sensor error. I've never had this GTE engine running without this error
