Hey,
Was out driving for 20 mins, then had a 5 min stop, when I then started driving and hit 3-4k rpm the car stopped pulling and slowed down. Kept it under 3k and drove home. Pulled a error code 51:
System: "Switch condition signal"
Diagnosis: "No IDL signal, NSW signal or A/C signal to ECU during diagnosis check."
Trouble Area: A/C switch circuit, A/C switch, A/C amplifier, Throttle position sensor circuit, ECU.
So I checked the TPS, replaced it, adjusted the new one, didn't get exactly the right values, but think it's ok. Started driving again, getting exactly the same problem. When going up to about 3000-4000rpm the car stops pulling and the sound it gets is almost like a antilag/limiter or something.
Is it then most likely the TPS circuit? Can't be anything AC as I don't use it..
Has anyone had this problem before? How did you solve it?
Scott
Scott
