WANTED PICS- MK4 rims with spacers
roadwarrior87
90
socal
I've thought about getting some kics spacers as well, but never got around to trying them out. There was a thread on SF in the MVP vendor section about these. Guy there said it good quality and safe. On alot of the other forums people use these as well for there stock wheels as a cheaper alternative to getting a whole new set of wheels. I haven't found too much negative info except the link below.
http://www.infinitifx.org/phpBB2/viewtopic.php?t=8286&start=0&sid=03f5ae9cf3c195064ebd49eb44fadcb3
WA
BorHor said:
Cool thanks that should be around the same for NA's as well.
oh, i thought we were talking adout the TT wheels. the rear mk4 NA wheel is 9" 50mm offset. so in that case, i would recomend a 15mm spacer with the built-in studs. however that would require a 10mm deep, 22mm diameter relief holes in the mating surface of the wheel. i have no idea if the wheels in question have this.
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Thats cool. The rears a almost to the point where it doenst really need a spacer so I am not worried about getting them in th rear. Maybe I'll get one of the ones that are sandwiched between.
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
I am going to order the 20mm Kics spacer form MVP now unless some one knows where to get it for less then $120 shipped.
