I've recently purchased a Walbro pump. I've been reading that they are prone to failure. they start to run lean after long drives and the pump getting louder. anyone know about this?
BrandonW;1295381 said:i was going to buy a walbro pump just because my pump and filter have never been changed out so i would rather replace them when i pull the engine instead of it failing when im driving or something
and not to thread jack but how are the bosch and denso filters? i heard they are not loud and are better if you have the extra money to get them, any comments on those?
p5150;1295372 said:I have a set of Walbros wired in parallel. One of the pumps failed and left me stranded. This pump has less than 200 hours of use. This is a legit pump.
I think the failure was due to the pump cavitating. Fuel economy isnt too good yet - still tuning. I left myself a bit short on fuel but honestly a pump shouldnt take a shit because you run out of gas..... Pump failed about 50 yards from a gas station. Initially, it just seemed like I was out of gas. The engine was out of gas... Thats about it; 4 gallons didnt help.
I could have wired the pumps separately, but I would have never known that one of them failed until I ran lean or happened to check the fuse....
Im going with twin Denso MKIV pumps now.
p5150;1295481 said:Do you want to know about the pumps or the filters?
BrandonW;1295844 said:around here you can get the bosch for $168 and the denso for $140 (replacement for the mkiii not the mkiv)
