Can I replace the stock fuel pump with a 255lph walbro without upgrading MAF and 550 injectors?
I have the fuel pump and the injectors (if they are the real 550s - ebay buy) but I don't have the MAF yet.
Can I put at least the fuel pump in until I get the MAF? Will the engine just send the extra fuel back to the tank? Will I run even richer than I already do?
I believe I need to replace the fuel pump asap to fix my hard starts. After it's been sitting for a couple of hours it has trouble starting. BUT after its running for at least 5 min it will start up and shut down no problems. I read somewhre that it could be a bad fuel pump check valve. I think it keeps positive pressure in the fuel system so it's easier to start. That's on the pump right? If that doesn't fix it, maybe the cold start injector is bad... Who knows.
Here is the link to the problem I'm having.
