W58 Used with a JZ Swap?
DonS1mpson
Black Supramacist.
Mar 19, 2006
674
England!
I’ve just be wondering.
We all know that that most common route for someone attempting to hook their JZ series motor up to a manual transmission is to use a R154 supra transmission with a 1JZ Bellhousing and flywheel, correct?
We also know that MKIV NA supras came with the W58,that means it will naturally bolt up to a JZ series engine. I’m also fairly certain that I’ve read that the bellhousing of the MKIV W58 can’t be exchanged with the bellhousing of the MKIII W58, correct?
So…
If one was unable for whatever to get their hands on a R154 bellhousing, and had no intention of passing the 400-450TQ limit on the W58 gearbox, could a gearbox from a MKIV NA supra be sourced and installed in a MKIII with a JZ series motor without any major medications? I’m guessing it would be a yes as the transmission was already available in MKIII’s, but I wanted to get some confirmation as I have no idea to what extent the MKIII W58 differs from the MKIV W58
Thanks
Josh
aphxero
787
Seattle, WA
I've done this many times in cressida. Here's the ingredients
mk3 w58 (for correct shifter location
mk4, SC, or IS bellhousing, clutch fork, throwout bearing
Good for about 350whp. Done and done.
supraracer49
3rd Gen Life
Nov 20, 2006
333
WNC
Im thinking about doing this because the W58 is so much smoother for DD but I have 2 R154's so I think I will never use the W58
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
I wouldn't use the W58 for a few reasons.
1. Can't handle more then 300-400 HP
2. Trouble sourcing parts
Unless you really need to use a w58 us it or else r154 will be the way to go.
str8_6
master yuepeng
Mar 14, 2007
241
wa
its torque mainly that kills the transmission and hard launching. i personally think the w58 is fine for the 1jz (more often less torque then 2jz/7m) for 350ish-rwtq max safe WITHOUT hard launches. my 1jz/w58 combo has been together for at least 3 years with occasional hard launches. torque is probably low to mid 300 and around 400ishrwhp on full boost.
some na-t mkiv guys have 500rwhp. i think the mkiv w58 has a bigger output shaft. i dont know for a fact though. they (the one that has actually lasted for awhile) say that to just roll off the line and dont shift hard. been working fine for me.
250sx
now|dig|friendly
Jul 1, 2007
189
SFL
what about the w55 (is300)?
I have a friend who's running it in an is300 w/gte block with 620rwhp/5xx tq.
DonS1mpson
Black Supramacist.
Mar 19, 2006
674
England!
But running a transmission from lexus would defeat the object of not using the w58 from the MKIV - The shifter is going to be in the wrong place.
How quickly is 400bhp at the fly coming from a 2J going toast a MKIII W58?
Is modifying a MKIV W58 to work in a MKIII going to be an ass?
Should I just suck it up and pay the $600 for a 1J R154 bellhousing?
Nomad707
Im From The Bay
Mar 14, 2007
1,039
Santa Rosa, California
w58's flood junkyards.
smooth shifting and great for DD
r-154 unbeatable reliability and performance supposedly "harder" shifting.
I have had both, and i can honostly say the r-154 is smooth shifting and not as much of a chore as some say it is.
I'd go r-154.
Later on down the road you might kick yourself in the arse
sorry for gravediggin
SupraMario
I think it was the google
The Farm
I'd go r-154.
Ditto, you go W58 and no upgrades to motor, and your going to have to learn to granny it, no fun, and you know your gonna wanna get on it alot after a 2jz swap.
Put in the R154 and save yourself some time, and beat on it all day. You will get used to the R154.
DonS1mpson
Black Supramacist.
Mar 19, 2006
674
England!
But the bellhousing alone for a R154 alone is an extra $600. You have to admit that's a lot of extra money to pay for that reliability, especially if you remember that I'm not going to be pushing the envelope power wise
Could buy 6 replacement W58s with that much :D
SupraMario
The Farm
2jz needs 1jz bellhousing, and DM has it for like 320 something.
DonS1mpson
Black Supramacist.
Mar 19, 2006
674
England!
I don't reckon the shipping quote is going to be too nice for Cali To London.
I have to pay rip off Britain prices, and it's £300 from Toyota UK :(
935motorsports
San Diego, CA
You can put a 2JZ W58 bellhousing on a 7M W58 transmission.
You can use a 2JZ W58 with an internal shifter modification. You will also need the top plate and parts from the 7M W58.
You will also need the 2JZ W58 flywheel and any standard 2JZ W58 clutch kit.
Guyana00
Droppin that JZ in soon!
Apr 18, 2007
1,208
Brampton, ON
I've been searching a little while now doing a mkiv w58 swap into the mkiii. Other than the internal shifter modification, will it work with the 7m-w58 driveshaft? What kind of shifter modification is needed?
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
the driveshaft should be the same but not sure about length.. i usually have a one piece made locally or a two piece modified
