I've been having problem with my clutch pedal engagement. Clutch disengagement doesn't start until when you have about maybe 1/8 inch left before you get to the bottom of the clutch pedal travel (watched cylinder rod movement and it matches clutch pedal operation). Also, the clutch does not engage until you have an inch left on clutch pedal travel (Hopefully I am making sense here). I have already bled my slave several times in hopes to increase pedal travel. I found no bubbles. No leaks either coming from the slave cylinder. Master cylinder is a brand new oem unit with no leaks detected. There is no clutch slip even at hard launches or all day driving so I am inclined that it is my slave cylinder but I need more people's opinions.
