I have my 1987 n/a almost all buttoned up but I have some loose ends regarding vacuum lines and a few connectors.
First.. I have a sensor with part # 90910-12024
It has 2 vacuum nipples on it (the one that protrudes straight out happens to be broken) and it has a brown connector on it.
I already attached all the vacuum trees, the blue VSV sensor and the ground wires to the bottom of the intake. The only threaded hole left is near the front of the starter. Is this where 90910-12024 goes?? I figure that it does because there is a brown connector that plugs into it in the same location.
Now.. here is the problem... there is another brown connector hanging down more near the front of the block under the intake manifold with nothing for it to plug into. It is exactly the same plug as the one that is in the rear that plugs into 90910-12024.
Where and what does this plug into??
I also notice that not a single schematic I have downloaded regarding vacuum sensors and fittings shows part # 90910-12024 which is described as a VSV. What is this thing for and since mine is broken.. do I need it?
Thanks!
Thanks!
