87witmoreboost;1260665 said:
Crisp, how did your car run with the VPC and stock injectors? Did you run any high boost? If so, what kind of AFR's were you seeing?
Okay, let's see... first off, THANK YOU ALL for this thread!!!:bowdown:
I'm an "arm-chair" tuner these days... and mine was a progression that goes back to 1996, when the car was procured WITH the PFC-FCON w/FCD, HKS IC/plumbing, HKS exhaust, EVC, TEMS, NOS (dual 10lbs. with heat/fogger nozzle) and a genuine HKS-BUILT!!! A/T, Art Carr converter and 4x4 truck-like 4.88 Precision Gears in the pig, making about 22% under-geared!!! (that's right... ZOINKS!!!:aigo
Okay, anyway... it was blowing through the stock CT, and years later, I went to a TEC H3 trim hybrid, and have always run 15-16psi, but the QUALITY of the PSI improved with the addition of:
VPC, GCC, 550cc HKS injectors, ROM upgrade, HKS SuperDrager, and a host of other progressions along the way.
AFR? What's that? DOH!!! Seriously, I've only ever had it monitoring EGR (HKS gage) and kept it at "controlled range" for where my probe is in the elbow, and other than a CRACK in the head (ex side leak) always "blowing/steaming" off coolant for a spell... (second "BHG", but more serious) with a fresh head, it's been running cool and a little rich, if anything since the 550's. (rich... presumed from my experience, plugs, exhaust "fart" behavior, EGR "creep" or lack thereof at varied PSI and loads... etc...) so I think I'm okay, but have an AFR (wideband) planned this next round.
...er... first question. YES, I ran the VPC with stock injectors (440cc) and "modified" rom in PFC-FCON, but NOT the 550cc rom. (Pretty sure there are at LEAST three ROM options for it...) My boost was kept at 15psi max, and it ran GREAT there for MANY miles. I even had NEAR 15psi (briefly, but would not hold boost anywhere NEAR to redline without fall-off) with the STOCK turbo with other HKS mods. Impressive even when I GOT it! The H3 works GREAT for what it is... and the A/T tranny was un-freakin' believable from a stop straight to pinned on the dial... all pull.
KOYO goes in it this spring, and maybe bigger turbo... thinking about the head/valve kit as well... and desperately need BBK. (WILWOOD! FTW!)
Oops! Got carried away...:biglaugh:
-crisp
