You guys, the rotor was dragging BEFORE I even drove them. (Just installed the rotor,caliper and pads, and then the wheel, and rotated the wheel, and noticed that it was smooth and free on one side, but on the other would catch as it went around.)
I then pulled the wheel, and re-tourqed the rotor/hat to make sure I had not caused a warped condition somehow. No change.
Checked the bolts holding the caliper, and the spacers? Nope, not a problem there either. Pads are fine. Everything looks fine, nothing is out of order, but the rotor was dragging.
Now, I thought since these rotors are zinc coated, possibly the coating was thicker on one part than the other? Also Precision noted that the brakes would not work right untill the zinc was worn off on the swept area, and the rotors seasoned by heating and cooling.
Before everything was installed, I coated the pads on the side facing the pistons with thermal barrier. (To limit heat transfer to the calipers/pistons and brake fluid) I'm pretty sure that the brake guys are going to say that's my problem, but I think the 6 pistons would equalize any pressure being put on the pads backing plate no matter what is coating it. (It came with some paint or powdercoating anyway. The Wilwood pads are made by Raybestos.)
If the rotor was coated with zinc that was not evenly applied, and then that caused the pad to deposit material in a uneven manner, it would make sense that the rotors are pulsing.
I only have about 1000 miles at the most on these brakes, I think I'm going to see if Precision will do anything about this. (I doubt it, but it will not hurt to see what they suggest.) Or I'm going to have to pay to turn these rotors and clean up the swept area before the pads wear anymore. (I don't intend to replace the pads, they are brand new.) I was hoping not to disturb the zinc coating outside of the swept area to limit rust, but if they are turned, it is going to make a mess of that idea. (And I'd want a nice crosshatch pattern on the rotors to re-bed the pads to the re-faced rotors, so that's going to scratch up the rotors too.)
Nothing custom is ever easy. LOL
