very bad and weird tranny problems. need help quick!
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
89Turbo said:
im at work i havent done it yet, it will be about 10-11pm tonight before i know
Lol, hopefully you're lucky, I'm overhauling the one in my black 88 right now......... ironically, I just received the overhaul kit today from a place in portland!:biglaugh:
89Turbo
804
Portland
PTW? Portland Transmission Warehouse
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
It was Transmission Exchange Co., BTW if any of you want the good stuff.......I.P.T. is FTW. 3 years almost beating on mine and I cant hurt it!
Got an IPT myself...barks the tires shifting 1st to 2nd. Kinda pricey, but so far it's held up extremely well.
89Turbo
804
Portland
UPDATE: wasnt paying real attention when i read this, and was lookin on the drivers side kick panel for like 10 minutes, but then i found it on the passenger side no problem(gutted interior) and pulled it. drove it around and did my manual shifting thing, man im not used to that, it did work but it still seemed kind of slow, is that because the work that i have dont on the trans is electronic and without that computer the "shift kit" i have doesnt function properly or what? so now i just have to determine if its the computer or solenoid.
oh and can i get a direct link to the A340E parts page on IPT?
89Turbo
804
Portland
i actually kind of like driving around manually shifting, is this a no no for a couple months while i save for a 5spd swap? i do have a big tranny cooler already hooked up to.
tinz
Wilson,NC
the 89 turbo auto i just bought wants to start off in drive,but it does fine if you manually shift it,previous owner swapped computer and still the same issue.any thought on this dilemma?
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
Start with easy stuff, make sure all your connectors on the drivers side engine harness to trans are plugged in, not damaged. Check solenoids, check continuity in wiring from ect ecu to solenoids.
