vents behind the windows
chopstickz
227
SoCal
yea. you have to remove the trim from the inside.remove the seat belt thing then pop some of those push in button things and remove them.
JoeC
338
Vancouver, Washington
If you're speaking about the black panels on the exterior right next to the doors.. then, you have to remove the trim from the inside of the car and there will be some screws you have to remove.
da89soup
World I Am Gay Blue!!!
Dec 2, 2005
1,978
Fargo ND
Yes it sucks ass!!! Start removing your interior trim from back to front thats how it comes out.
Brewster
So it goes.
Apr 15, 2005
1,156
Morgantown, WV
the fun part is when the nut rusts onto the bolt and the bolt will spin in it's plastic holder.. so then you have to rip off the vents and cut off the bolts..
you'll need deep sockets. i beleive its an 8.
turbo4toy
208
Los Angeles
I'm going with a 10mm on the bolts and yes its fun. Its a hell of a lot easier when you take out your entire interior to replace it with shadow grey.:bigthumb:
But really its not bad just be careful not to break all of the clips when taking the old trim off.
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
Yep, remove trim, there will be 2 8mm nuts holding it. the studs are in the plastic piece. then its one lttle clip in the middle u can just pop it out or push it out :) easy job. but i hate having to remove the trim on the inside :(
