satan and goliath: Would you say rain and dirt easily enter these holes or are they pretty safe to use?
goliath said:The black supra in that ebay ad are not what you would recieve.
The ones that Satan has are what you would get.
Here's mine
http://www.cardomain.com/ride/554635/4
BlackMKIII said:I was considering buying some...
Then I left my ricer days behind. :rofl:
Sorry, that's just my two cents.
Skam9685 said:satan and goliath: Would you say rain and dirt easily enter these holes or are they pretty safe to use?
starscream5000 said:Nice setup you've got going on there!
Grimsta said:Ok, Pep Boyz has this "Spectre" piping. They come with different bends and stuff.
For a turbo you'll need 3 60 degree bends, a vacuum port pipe, and vacuum port kit, some hose clamps, couplers, the MAF adapter plate for the non turbo Supra, and a 3" cone if you dont already have one. K&N FIPK will not work.
First 60 degree comes off the turbo, use a coupler to fasten it, then attach the vacuum port pipe for the BOV, and IAC lines. YOu'll have to drill one of the holes on the pipe larger for the larger vacuum port for the BOV. Once you got that in, use the 2nd 60 degree bend to face toward the front of the engine. Using couplers attach the AFM to the end of that pipe.
On the other end of the AFM attach the MAF adapter. YOu'll have to redrill the holes to have them line up correctly (easy) and use the Supras gasket on that plate. Then attach the final 60 degree pipe onto the adapter and have it dip down into the hole behind the headlight. Using dexterity and contortionism reach up the fog light hole and attach that 3" cone to the pipe, POOF! Custom Pep Boyz cold air intake for $40. I think i'm gonna make a thread of this so i can just cut and paste easy reference, is that ok?
Use
