Venom 550cc
MKIIINA
Destroyer of Turbos
Plano, TX
PorterzSupra said:
I dont know why all you guys bash venom injectors, you think just because something is cheaper that means to must be junk, thats rediculous!!! You have no proof that they are poor quality. I have been using mine for quite some time with no problems, they work great. I remember when ppl use to bash the xs power turbos because they figured they were so cheap they had to be junk, some of you actually said they were held together with "glue" and it would just "melt" when they heated up and fall apart ROFL grow up guys!!! just because something is less expensive does not guarentee that it is garbage.
we actually have a pic of that.... the compressor cover is off and you can see the epoxy. myth is great until you get evidence.
Cheap isn't the problem here it's when guys try to extract huge HP from these parts is where they will fall over!
A Motor at it's limits will only need a fraction of a hiccup to selfdestruct and while the more affordable parts may be ok in a DD or a moderate HP build when pushed to the limits you'll end up regretting saving a buck :(
