Venom 550cc
huntin5L
Niles, IL
So ive done some searching, and i guess i just bought a set of injectors that nobody trusts lol. Well, i was thinking about getting them flow tested, what usually does this cost and where can i take them too? Also, does anyone else make direct drop in injectors or is it just venom?
jkbmkiii
539
Castle Rock colorado
venoms are just re worked stock injectors, I seen to many people say bad things about them..... I guess you will know if they are worth it if you have them flow tested!
huntin5L
Niles, IL
yeah, this is true i wonder if it is even worth getting flow tested. What is the name of that site i should get an estimate anyway.
Zach
ECUMaster USA
Apr 6, 2005
375
TX
I emailed the Venom vendor on ebay, and he reported that the "direct drop in" injectors use new denso cores and different internals to gain the flow they advertise. I'm probably going to pick up a set so as to avoid hacking up a new engine harness to put injector clips on it.
MKIIINA
Destroyer of Turbos
Plano, TX
there seem to be 2 types of venom injectors btw. theres the bored out stockers and then new units that use the above cores like Zach said. the bored out ones are the problem ones and the new cores are ok.
huntin5L
Niles, IL
apparently the guy that sold them to me said these are the new ones that are not the ones sent in to get modified, but i might still sell them...I don't know. I got them for 250
PorterzSupra
703
Hebron CT
I dont know why all you guys bash venom injectors, you think just because something is cheaper that means to must be junk, thats rediculous!!! You have no proof that they are poor quality. I have been using mine for quite some time with no problems, they work great. I remember when ppl use to bash the xs power turbos because they figured they were so cheap they had to be junk, some of you actually said they were held together with "glue" and it would just "melt" when they heated up and fall apart ROFL grow up guys!!! just because something is less expensive does not guarentee that it is garbage.
