I found a few testimonials about the tornado gimmick online.
http://autopedia.com/bbs/tires/messages/5903.html
*Please spread the message*
I bought a device called the Tornado Air Intake last year. It is a "turbine" to be put inside the air intake hose.
Has no moving parts but is supposed to create a swirl effect in the air and make the combustion more
efficient. see www.tornadoair.com The company claims it increases mpg and horsepower. My experience is
that milage suffered and the car performed worst. It probably costed $5 to make but the company charged
$70 for it. I should have known better. I hated being a fool but what I hate more is if some other car owner
fall victim too. Please spread the word.
http://autorepair.about.com/cs/productrevi...aafpr052002.htm
The mileage test was done with the mileage from three tank full's of gas and averaging them out. The same tests were done after the Tornados were installed. Fuel mileage on the Chevy Pick up increased by .2 mpg and the Lincoln Town Car increased by .1 mpg. The mileage on the S-10 decreased by .4 mpg. So much for the fuel mileage increase.
How about the increase in power? All three drivers said they felt an increase in power after installing the Tornados. I put them back on the Dynamometer to see how much the power increased. We got the same horsepower readings on all three cars, no increase in horsepower. I asked the drivers why they said their cars had more power and they all said, "Well, it felt like it had more power."
After these two tests were done, I did another emissions test. As with the other two tests, there was no reduction in the exhaust emissions of any of the test vehicles.
The feel of increased power is what the consumer expects to feel. So it is a matter of perception.
Draw your own conclusions...
Another test of the Tornado:
http://www.klio.net/creasy/probe/perf.htmlSpiral Intake a.k.a. The Tornado (Back to Index)
Here's what I found on the dyno. The data is uncorrected and smoothed (to avoid getting too many unbalancing peaks) to S=3 on dynojet's software. I made six passes on the dyno. Two with the Tornado unit installed followed by a 20 minute cooldown (with the engine idling) and two runs without the Tornado installed. Following yet another 20 minute cooldown with the engine idling I proceeded to make two more runs with the Tornado unit installed.
Run #1 w/Tornado: 145.1 HP, 147.3 lb-ft Run #2 w/Tornado: 145.3 HP, 146.7 lb-ft
Run #3 noTornado: 148.0 HP, 149.8 lb-ft Run #4 noTornado: 146.8 HP, 149.3 lb-ft
Run #5 w/Tornado: 145.6 HP, 148.8 lb-ft Run #6 w/Tornado: 146.3 HP, 148.4 lb-ft
As you can see from the above numbers, coming in "hot" from the street produced the lowest numbers. I did allow for about a 10-15 minute cooldown before hitting the dyno the first Time. So perhaps the second run wasn't surprising, with the car probably being a bit cooler. The third set of runs is what put the nail in the coffin when it comes to the Tornado. Although the third set was a bit improved over the first set, it was still visibly lower than the second of runs. (thanks to JTT)
Yet another snake oil automotive product.
tubbie said:It's an intake restriction....
