Valve Removal Tool
To remove the valve locks?
I use a deep socket (plug socket) with a piece of rag loose over the valve cap then give the socket a hit with a hammer, the rag stops the collets/locks from going ballistic then you just repeat 23 more times and they're all out :)
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
right right, i also know another way of gettin it off, but putting it back together involves buying a valve remval tool, no?
so these "collets/locks"....i know them as keepers..thats the same thing right?
t4boost
I gotta have my boost!
Mar 23, 2007
106
Arizona
That looks like one you use when you have the head off, I am assuming you do. I have a bluepoint keepers tool works really good for heads on and off the car and I dont think that it was that expensive $60-$70. It has definatly paid for itself for the amout of times i used it though. being at the dealer.
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
yeah it would be a good idea to get a good one, but frankly, i dont want to dish out a lot of money because i know the next time i use it after this is...i have no idea when..how does that one look on that site i posted up..would that make it happen?>
I've made the claw style ones work, you gotta bend the arms so they grab ahold of the bucket guides on the outside...
Stu_22
124
England
Be careful when using the hammer and socket method. I did this when stripping down a head off of my euro hatchback and got a valve spring in my eye.
I had given it a big whack but one of the collets was still half in then it let go and the valve spring shot into my eye. My fault in a way as it should have been pointing away but just a reminder for all
Hence the piece of rag inside the socket.......
I always give it a few whacks to makes sure the springs have let go before moving it away as well as wearing safety glasses whenever I'm in the shop.
(Had a 12mm Carbide cutter explode in the CNC today and I still can't account for 1/3 of it so I'm a bit paranoid about eye safety)
Dub:
Apr 6, 2005
339
Alpharetta, GA
Darn Brian,
I can understand the cost for that unit; box tubing with welded gussets. I suppose it meant for "superlarge" & "superstiff" valve springs :biglaugh:
For a less expensive version, here is the one I have and have used several occasions -
http://cgi.ebay.com/ebaymotors/VaLv...tegoryZ43996QQihZ002QQitemZ120108674665QQrdZ1
Slow66 said:
heres the one i use....
http://www.goodson.com/store/templa...IID=5591&SID=bb65c104edc557c80ee3e920370286a2
Yeah its pricey, but it works really well, and makes my life a bunch easier. Not to mention, i can use it on pretty much any head i come across.
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
BlackDevilSupra said:
Darn Brian,
It does work real well with stiff springs, and is smooth as silk too. I love the thing :)
