Vacuum Issue's and understanding why it's happening ?
8,897
Turbo Habanero;1861954 said:
Could a pre turbo exhaust leak be a culprit?
Of a vacuum leak? Wrong manifold.
The KV meter can not account for humidity like a hot wire mass airflow sensor can. Just so you know.
Turbo Habanero;1862064 said:
My Tps is also throwing all kinds of F up'ed Voltage according to my AVC-R but no engine codes it likes to read 36% throttle when i'm not touching the gas.
On a side note, you don't have wires twisted together and taped to cover do you?
Turbo Habanero
4,229
Tucson,AZ
Not exactly they were installed with quick splice clamps. (Which might not be much better but i didn't want to hack into my new harness to solder them.) Other then the TPS voltage being off sometimes everything works great.
Also when the TPS voltage reading is off I can blip the gas a couple times and it will return to normal.
Thank you for the info Nick.
