I have read and read several threads related to different ways of testing for a vacuum/boost leak, some test more of the system then others...
My theory was that the more I can leave hooked up the better, otherwise you don't know if it is leaking where you took it apart and put back together after the test.
This is what I did, let me know if it was a good or bad idea...
Removed AFM sensor and sealed the two holes on top of afm body.
Removed the two T's that went to vents on valve covers for pcv system and capped them.
Isolated the EGR valve at the Plenum with a solid gasket to plug hole (1st round left EGR connected, found small leakage which I understand to a degree is normal, so wanted to isolate, as it distracted from hearing other issues)
Capped the afm body (intake side) after removing air filter
Capped the tailpipe.
Introduced air at the sample port on the bottom side of turbo (normally connects to the wastegate.
Set at 15psi, sprayed soapy water for visual and listened to see if I could hear anything...
Did it makes sense to do it this way, if not please explain so that I can make sure I am fully testing the system... I will not get into why on this thread... I have exhausted a couple of others already, I just want to make sure I am testing for leaks correctly and safely.
Thanks
Thanks
