vaccum nipple
supra1642
113
Michigan
does anyone know this part? it has/had 2 nipples the left one goes to the bottom of the accordian hose and where does the other go?
thevork
ShoarmaTeam Member
in the mean time, cap off the vacuum hose going to the part that you broke off. it's a hardline coming from the front of the engine (it's in front of teh timing belt cover) going to that piect you're missing. If you don't cap it off you'll have a vacuum leak.
jdub
Feb 10, 2006
10,730
Valley of the Sun
It's shown in the pic:
That valve (#17630) is used to increase idle when turning the car at low speed. It does need to be capped off on the hard line side until you get a chance to replace it.
thevork
ShoarmaTeam Member
That's strange... You sure?
It seems that it's a straight connection to the vacuum on the intake.To me it looks like not capping it off will cause a leak ?
jdub
Feb 10, 2006
10,730
Valley of the Sun
Yep...idle up for powersteering at low speed.
Actually, you are correct...technically, it needs to be capped off on both sides. Not capping it off on the accordion hose side will allow unmetered air into the intake.
