Thanks, I'll make sure the harness is repositioned when I put the motor back in. The wiring harness is supposed to run inside the intake manifold and under the throttle body, right?
I'm almost ready to install the motor after a rebuild. MDC...do you know how much knock sensors go for (replacement)? Both of mine cracked and the plug/wire just dangles from the hex/metal part that screws into the block.
