cjsupra90 said:Actually the supra is built to drag to a point, I am not sure of what all suspension work is done, and I am sure that more could be done and the mustang is mildly built for draging also, but nothing major. I do know for a fact they are both running slicks (not D.O.T drag radials but full on slicks) and they are both great drivers. Example, they switch cars and still run almost identical times in that respective cars.
HP is what is needed to sustain a particular speed not accelerate a load. Look at your average semi truck engine. They produce between 300 and 500hp and yet produce between 1000 and 2000 lb/ft of TQ plus the extensive number of gears with in the drivetrain. Try hooking your a 1000hp supra up to a fully loaded truck and trailer and try towing it (not going to happen). Ask any mechanical engineer whether gearing is a multiplier of torque or horsepower and they will all tell you that is torque. Here is another example of torque Vs Horsepower, look at your average F1 car, they produce almost a 1000hp and weight in at under 1600lbs (half that of an MKIV) and yet only average 9 1/2 sec. 1/4 mile times. This is because they only produce between 300 and 400 lb/ft of torque.
Im not trying to argue with anyone, just giving proof positive examples. Anyone who doubts me should go and do more research on HP and TQ
im still not completely with you on this....... if torque was the only thing that mattered (or even mostly mattered) in getting a car down the track, then how do you explain that all sports cars are gas powered.......??? im not being cocky or anything, im seriously asking, horsepower moves cars too. for example. adding a lightweight flywheel adds horsepower, but very little or no torque, yet the car becomes faster. free flowing exhausts on na cars don't add torque, they add horsepower, yet they get faster. also about the f1 cars, they have no suspension and if you have ever witnessed a kart car accelerate, its nothing short of amazeing. they aren't built for drag raceing. they are built to turn. road and track or car and driver (i don't remeber which) did a test of cars accelerateing flat out for 1 mile. the f1 car they had ran a 9.5 in the 1/4, but the amount of down force it creates even at those speeds is incredible. take off all that downforce, and that car goes a TON faster in the 1/4. also, first gear does like 70-80 mph..... not exactly helping 60 foot times. by the way, im at college in my 2nd year going for my mechanical engineering degree and i think both horsepower AND torque are cool
