Jeff Lange;1586366 said:
I would like to take this time to say that only JDM 7M-GTE's out of Soarers have different oil pressure senders. JDM Supras have the same sender as USDM.
Jeff
really? ive had 3 different jdm 7m's, one in each car (at various times), the oil pressure always had to be swapped out in order to get my gauge to function...
in my 89, I swapped in a JDM 7MGE, oil gauge didn't work, and then later on I swapped in a USDM 7MGTE, and it worked just like the day before the original swap. Then on my 86.5 once the JDM engine it came with went out, I swapped in a 91 7MGE and the oil pressure gauge started working again, so when I bought the 92 with a BHG, I swapped in a JDM engine and had the oil pressure senders swapped in order to avoid the same issues..
Also I'm sure the JDMs were all out of Cressidas...but now that I think about it, it may have been possible for Soarer 7Ms...
