Upper ball joint replacements (front & rear)?
Satan
Tampa
Have searched and read alot about replacing the whole arm, and even the option of using a GM BJ.
Has anyone successfully used a commonly found balljoint to replace the Toyota ones (without replacing the whole arm)?
I am installing the poly bushings and mine look tore up. I am sure I can reinstall and be okay, but if there's an easy/available option, I'd like to do it now.
Thanks!
themadhatter
760
Vegas
I would be nice if just the ball joint could be replaced but I don't know f there would e a way to get it out with out messing up the aluminum arm
Satan
Tampa
I saw a thread by Cuel that mentioned how he had to cut out, trim some metal (machine shop) and press in a GM one (which also had to be trimmed some), but the attached pics did not work.
That was in 2007, so I figured someone may have done something different/better by now.
I also thought that maybe they're held onby a snap ring of sorts and that equivalent ones coule be insterted, such as the Tacoma ones in this auction... http://cgi.ebay.com/ebaymotors/Uppe...trksidZp3286Q2em20Q2el1116QQitemZ230252016057
