Upgraded CT-26 worth it?
gilberjj
Friend of Fast
Apr 14, 2006
661
Tacoma, WA
my turbo will make a little more hp then a ct26.... but i don't get usable boost at low rpms anymore :cry:
now i usually downshift when going up a hill on the freeway. but i don't mind at all, cause you never race under 3k rpms.
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
Bigdough666 said:
60-1 w/10 degree clip here, with almost no tune, I made 371 RWHP. It spools quick, pulls hard to redline and keeps on doing it. Going on 4 years with no probs. People trip out when they see the little baby turbo under the hood. Its 10000000% worth it.
What are/were your mods?
Bigdough666
Picture Me Rollin
Apr 4, 2005
367
Corpus Christi, TX
Built Internals
K&N
BIC DDP
BIC Testpipe
Custom 3" HKS Carbon/Ti catback
Lex AFM/550s/AFPR/Walbro/S-AFC II
NGK Iridiums/Moroso Wires
Dr. Jonez MBC maxed out ~20psi
Ebay special FMIC w/custom 2.5" hardpipes
HKS SSQ BOV
Spec Stage 3
Thats pretty much it. Stock head/cams, intake, etc. And I later found out my LSD was pretty much dead and I have a valve seal leaking oil into at least 2 of my cylinders. Like I said, I made 371 RWHP and it has only enough tune to run. In fact, it was all over fuel cut on the 1st dyno run and it was barely able to make a full pass on the 2nd pull. The AFRs are 10:1 or worse. Once I get it tuned, it should make plenty more power.
