upgraded coil packs for 1jz/2jz
charlesshen
256
orlando
ok so i think my coil packs are going bad on my 1j at least that the conclusion they have hair line cracks on them -so does any on have upgraded coil packs or no of any other after market performance coil packs form another car that well work ?
my friend told me some msd mustang coil packs would work and that i just have to change the connector but i dont want to wast my money on some BS that might not work any one head of this before?
figgie
Twin Cities, Minnesot-ah
no such thing... get some new ones or used ones in known good condition and call it a day.
the GM dual coils will work in our cars but not sure how they will do with boost.
charlesshen
256
orlando
lintlars;1171635 said:
Im running the MSD gm style for 3 years now work great under boost you have to rewire buts it quite easy.
no rpm problems nothing and do you know the part number for them off hand?
tissimo
Stock is boring :(
Melbourne, FL
Just put clean nail polish on the cracks and wrap them with 1" heat shrink (the whole tube). They should be fine then.
turbo87targa
482
colorado springs
j3pz;1171684 said:
check out the COP sticky in the 7mgte forum, step by step of how to replace the stock coils with the 2jz vvti coils. seems the hardest part of it is finding coils (unless you get em new)
so that cop setup is an ugrade aswell as bay cleanup?
Doesn't DM carry those coils for the cop setup?
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
Instead of using COP is there a way to upgrade the system and use Direct Fire Ignition System DFIS because my 4th gen Altezza engine(3SGE B.E.A.M.S. Black Top) came factory with this did toyota start using this after 2000? on all motors, input would be apreciated basically its like COP except it also built the ignitor componenets into the COP pack eliminating the ignitor modual making the engine bay a little cleaner.
