I just recently installed all the upgrades necesary to run higher boost(60-1, 550's, walbro, lex afm yadda yadda) and i turned up my manual boost controller in hopes to run 18psi. Well it kind of runs 18 but not quite. Each gear gets slightly more boost than the last. 1st gear will pull 13psi, then second gear gets 16psi, and by the time im in 5th i can build, well 20 is as high as ive seen it spike to. does anyone have any ideas on what might be the problem? Boost leak maybe? thanks in advance.
Scott
Scott
