Under hood insulation
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
GrimJack said:
Mine is just primer under the insulation. Kinda makes the whole 'my insulation looks like crap' debate a moot point.
yuor hood has bean to both wars and back
born2drv
1,199
Burbank, CA
i have the cusco strut tower bar and the padding would make contact with it and leave spots that got burnt into the aluminum..... so after searching the forums for all other supras with cusco strut tower bars i realized everyone removed theirs, so i did the same.
had my cusco tower bar polished and chromed to get rid of the marks the padding left, and so far so good looks beautiful ;)
when i get my car painted i'll be sure to paint both sides of the hood.
Jeff Lange
Administrator
4,919
5
Sunnyvale, CA
jefflange.ca
Are you sure your hood wasn't replaced and then just not painted underneath?
Is it primer, or is it satin black? OEM Toyota parts are satin black when unpainted.
Jeff Lange
Administrator
4,919
5
Sunnyvale, CA
jefflange.ca
GrimJack said:
It's primer grey. Could be a replacement, I'm not the original owner, but the paint on the hood (top) looks original - read, looks a LOT older than the paint on the rest of the car.
Yeah, but if someone is good, they can do it and nobody will tell.
My hood was repainted a couple years ago, and I can't tell, heh.
Loki
The Future is Unwritten
Prince George, B.C.
My hood is like that as well, I took off the insulation because my blow off sits kind of high for some reason and hits the hood :icon_conf
NashMan
Aug 5, 2005
4,940
17
Victoria BC
hey grim you chould bring back you hood i done it befor thisnsi the meathon i used
spray water on hood use simple green spray and scrub it as good as you can
what this does is takes every thing off the paint besides the paint
after that spray hood wiht water and take some stuiped high grip sand paper the highest the better lighty bush your hood as even as you can
after that get magera posih and buff the liven crap out of it after that just wax and i bet it be like brand new hood
BTZ
Burnaby
both my supras had the stock paint color under the hood. I figured by removing the insulation it would allow a little more flow from the engine to the vents and would not trap the heat in by acting as a engine blanket.
