Under hood insulation
ians13
537
Jacksonville, fl
My under hood insulations looks like crap and is fulling off, is it a bad thing to remove it, wille it cause any dmage to the hood paint and such.
supra90turbo
shaeff is FTMFW!
MA, 01440
Some say yes, but I'll say that I was running for a year and a half, even with missing heatshields, with no hood insulation and my paint was juuust fine.
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
im gonan take mien off soon. i looked thorugh it and there didnt seem to be anycomplains on a bunch of celica alltrac guyswhen htye remove theirs soo..
Yellow 13
Lurker
Apr 4, 2006
2,308
Fairfield, California
What does it do absorb heat? It looks like household insulation inside so wouldnt it keep heat in the engine bay like home insulation keeps heat in a house? My only guess to its benefits is that it would keep the hood from flexing due to excess heat.
mixmastermatt
Former Nissan Junkie
Mar 30, 2006
124
Taftville, CT
You'll hear a lot of differing ideas on the purpose. Some will say it is to protect the paint on the hood from the heat of the engine. Others will say its designed to smother engine fires. Personally, I am removing mine next time I pop the hood, if I remember anyway.
xarewhyayen
276 whp - 324 tq @ 13psi
Oct 3, 2005
959
Philly
I dont think it so much absorbs heat, i think it produces more of a spreading action instead of the heat coming up and concentrating on one spot ( probably eventually have a heat spot on your hood above the turbo side)
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
I've heard all of the theories, but the fire smothering one is by far the best. The plastic clips attaching it to the hood would melt off in the event of a fire releasing the blanket onto the engine, and in doing so the fire would be smothered hopefully.
eric
supraman7mgte
Shut up,bitch!!
Sunny California
i took mine off as soon as i got my car.
it's pretty much designed to absorb engine noise more than anything.
burn? hell yes,with the right chemicals...and lighter...
SupraManDrew87
Picture Me Rollin
Apr 4, 2005
26
Tucson, AZ
Yes it burns. I'll get a pic of mine if you want.:nono: My oil pressure rose on the freeway, and my plastic radiator top busted open when my water pump died. Oil leaked out of the bad valve cover gaskets onto a heat wrapped header. A small fire ensued which was doused with Gatorade. LOL. Stranded me in between Tucson and Phoenix in AZ. :cry:
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
take the shit off it's most likely soak in alot of oil grime any way
it there to stop a fire or stop paint from bubbling ect but you cna live wiht out it wiht no concerns
59blane
Lovin' Life
Apr 20, 2006
Beautiful Elk Grove, California
Yeah... I agree, if it's in bad shape and dirty, take it off. I had a '67 Pontiac Catalina (Gunboat on Wheels), and the a/c pump froze while I was driving, friction caused the belt to burn, in turn setting the underhood insulation on fire. That definately resulted in bubbled paint... :)
