undampened crank pulleys
jdub
Feb 10, 2006
10,730
Valley of the Sun
It's the harmonics of the crank that causes the problem...it's hard on the bearings.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Glad it amuses you :sarcasm:
Not sure if a 4ag uses a dampened pulley or not myself...if it does, you don't want to use anything else that's not dampened.
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
Yea the 4a uses dampened also... so i would expect same end result.
I was wondering about aftermarket pulley's for the 7m as well, is there a hp i should be changing from the stock one? Is there any telltale signs of failure that i can look for? And who does aftermarket ones that you recommend?
Thanks :D
Jeff Lange
Administrator
4,919
5
Sunnyvale, CA
jefflange.ca
I didn't think the 4A-GE's was dampened. I haven't looked at one in a long time though, there's too much stuff in the way in my black car, lol. I'll take a look tonight I've got one out of the car right now and another on a 4A-GZE in my garage.
Jeff
selfinfliction
434
ky
what kind of weight difference is there between the stocker and the ati?
i just shot IJ an message this morning about that exact topic, asking if it would still be beneficial to run a dampened pulley on a zero balanced rotating assembly
jdub
Feb 10, 2006
10,730
Valley of the Sun
suprra_girl;923166 said:
$399usd from Summit
I'm gonna go search Ian's thread to find a pic of his ati :)
Ians pulley *drool* hehe http://members.optushome.com.au/ianj/ati01.jpg
SIP Racing (suprarich) has ATI Dampers for the 7M...might be worth a PM for the 4AG.
They are actually a bit cheaper than a new stock damper from Toyota ;)
A little over 5 lbs lighter and the AC pulley can be removed.
Yes...you want to run a damper even on a zero balance assembly. Even better is to balance with the damper and fly wheel/flex plate bolted on.
selfinfliction
434
ky
yeah i was reading today on some bmw forums about using a lightened flywheel in combination with lightened non dampened crank pulley, seems there's alot of horror stories about it causing spun bearings.
i was just gonna cheap out, but those beemer guys seem to swear by using only dampened pullies on an inline 6 motor
