Ultimate Turbo for the 7MGTE
drjonez
the motor city
www.4cefed.com
gixxer750 said:
I make full boost by 3400-3500 on a DBB t66 turbonetics. The car begins to pull hard right around 3000, and I see 1 psi positive pressure right about 2700rpm in third gear. (and for first gear, antilag/two step helps a lot.) Also makes 500 on pump gas around 15 psi.
gixxer750 said:
...88 turbo AEM 7M powered gutted out race/street car...
ah the magic of standalone.
unfortunately, as already stated by the thread stater, they're low on cash.....so not a useful comparison.
supramaze
wizard
Sep 29, 2006
29
Sweden
dbsupra90 said:
500rw on pump gas is going to mean a 64-67mm turbo. none of those are going to hit full boost under 4k rpm, but they will be making boost at that point. best deal i have going is the 67dbb which will make the power and help with spool. but sounds like even at 1149 range its more than you want to spend.
lag will also be effected by turbine wheel, turbine housing, and the rest of your setup.
where can I get a 67DBB for 1149 ? any links pls
thanks
supraguy31
626
Pembroke, NC
I want to say thank you to all that Posted here. I was great reading and see what everyone was running and/or what everyone recommended or wanted for themselves.
So here is what I decidedto go with since Ive took all the Knowledge from reading here and did some research.
ITS GT66 Ball Bearing turbo. Compressor is a AR.81 and Exhaust is a AR.68. Im thinking it should spool pretty well and for what Im planning should be more than what I need. States that the turbo is good for 600+ and spools pretty Quick. I guess I will see one I get the Exhaust built.
fast 7m
track forged son!!!!!
Apr 19, 2007
portland
www.trackforged.com
I have gt35r turbo set up with cams, the spool is pretty fast. I have full boost at 3700 rpm. I also have a apexi boost controller that allow better boost control. gt35r great choice 57mm
