U Joints
Justin
Speakers?
Spokane, Wa
Is there anything tricky or special about replacing the driveshaft joins? My driveshaft is clanking pretty hard when i accel/decel so I'm pretty sure the joins are shot...
Is replacing 'em as simple as any other car?
M
mattonedime
Guest
Sorry man the stock U-Joints are not servicable.. Only a driveline shop can change them out for you.
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Mattonedime: Thanks for clearing that up. I have seen on my supras over the years drivelines with serviceable joints and factory ones. I guess it depends in Justins case if some one has already been in there and torn it apart.
Asterix
Lurker of Power
Vienna, VA
The service manual tell you how to replace them. http://www.cygnusx1.net/supra/library/TSRM/pr/PR_05.html
Whatever you do, don't beat them out with a hammer like I did. If you have a puller that fits, it's not hard, though I'm sure a shop can do it for not much money.
Check for play in your transmission's output shaft bearing. Mine got quite loose and sounded a lot like dead u-joints.
Asterix
