suprarich said:The rule is MK 1-3 1jz or 7m is a class. No rule yet on a 1.5jz.
A 1.5jz IS a 2jz motor with a 1jz head. IT IS NOT a stroked 1jz. A stroked 1 jz is a 1jz block with a longer stroke crank installed. In comparison, a SBC 400 with a 283 head on it is not a 283. It is a 400.
This is still a grey area in the rules. The drag rules are not set up for body type at all, and will never be. There are many classes just for mk4's, They are not piled into one class either. The rules are set to make a more level playing field.
And yes, if some one puts a 7m or a 1jz in a mk4, then it should run with the mk1-3 class.
I personally say a 1.5jz is a 2jz with a 1jz head. Call it a 1.5 all you want, the simple fact is that it is still a 2jz motor now. On the other hand i don't really care where they run because I will kill all of them with my 7m next year anyway.
If it were decided that 1.5jz ran with mkivs then someone build a stroker using the stock 1jz block making it a 3L 1jz would they have to run in the mkiv class as well? There is no real difference at all. The block is a bit taller, and thats it.. oh and the 2jz stamp on it.
And SBC are rated in Cubic inch, so it isn't a vailid argument cause 350 != 383, but it uses a 350 block..
