two step
Status
Not open for further replies.
shaeff
Kurt is FTMFW x2!!!!
11
Around
oh. my. god. when did people stop reading!?
that is all
meet07
49
Wake Forest
found this about the Gizzmo Launch controller:
Gizzmo's launch Interface integrates with the Gizzmo Tach Recall
Shiftlight to enable the fully adjustable launch control function. The launch control function induces sequential misfire events at the desired rpm set by the user.
In a turbo application, having the throttle open while inducing misfire
increase the velocity and density of exhaust gases, allowing the turbo to spool up and generate boost with load. This results in boost being
generated before launching and therefore allowing a vehicle to launch with considerably more power. The ignition cut is clutch activated
allowing flat changing (the ability to change gear without removing your foot from the throttle). With the clutch engaged the rpm will pull back to the launch rpm previously set by the user in order to avoid over reving, this results in the vehicle not coming off boost while moving through the gears.
Launch control can benefit natural aspirated cars by giving a consistent launch rpm for best results every time, and enable quicker gear changes through flat changing.
Compatible Vehicles:
All Nissans
All Subaru’s
All Mazda’s accept Rotaries
All Honda’s
All Mitsubishi’s
The Rules:
Typically the launch interface will work on any car that has an Igniter that …
1. A) is triggered via the ECU
2. B) is not inside of the ECU
3. C) have not got a feedback system to the ECU e.g.(Toyota)
4. D) have not got a ignition control box that encompasses the igniter e.g.(Holden Commodore V6’s)
Vehicles known that are not compatible
All Holden V6’s
All Toyota’s
All Diesels
drjonez
the motor city
www.4cefed.com
i was about ready to close the thread....but these posts begged approval...
meet07 said:
what about AEM?? Do they not offer it for the 1jz??
of course the AEM does it...this is the PIGGYBACK forum.
no AEM for the 1J.
<SNIP>
All Toyota&#8217;s
try reading post 16......heck, trying reading what you posted!
Status
