Ok I'm going to be buying two sets of twins (got a good deal) and was planning to run the two best turbos. My question is. If the secondary turbos are in better condition (which i would assume since their not used all the time) Can i just swap the cartridges into the primarys?
Are the Cartridges exactly the same ?? I dont have both my turbos with me right now to check ( Im out of town atm ) so i cant check.
Basicly if i swap a secondary cartridge into a primary housing will all the oil and water lines still line up ?? and are the Roll prin alignment holes in the same spot ??
Thanks in advance
Edit: 2JZ twins
Thanks in advance
Edit: 2JZ twins
