Many engines are run without intercoolers, but they were designed for it with lower compression and less aggressive timing maps. Instead of running no intercooler I'd just find a very small one to route basically on the piping.
Devin Hutchison;1827049 said:That spells bad news for a turbo. You'll over heat fast. Ive got a stock intercooler and a 57 billet ct 26 and I'm getting heat soaked pretty badly on hot days. I'd suggest some type of intercooler and fan setup.
Sent from my PC36100 using Tapatalk 2
NashMan;1827325 said:^ bingo
I was going to do this for under 500 including every thing (cheep)
stock 7mgte's can destory a rear ring and pion rather quickly if lead footed
the frist plan was to keep it na and see how it went any way
I still am on the hunt for ka24de that is the motor I really wana put in then mate it up with the w56
MPR;1827997 said:On a bush truck/crawler, I would think a turbo would be nearly unusable. For those who have stock 7mgte's, at what rpm does it start to make useable boost? 3000+?
I have a stock NA 7mge and I love it's tractor like low-end instant torque. I would think it should be more than sufficient for an off-roader/crawler and be much more controllable power as well.
Just don't see the point, especially considering the application, imo.
