Turbo Won't boost
speed
Gone. Email me.
May 27, 2006
1,045
not here
www.timduganphotography.com
took off the BOV, its in fine working order, but i lubed it up anyway. I double checked ALL the couplings, and found a small tear in one, replaced the couplings, and the turbo now boosts.
But...
It still doesn't act as before, its very sluggish when building pressure. It doesn't throw me back like it used to.
ugh damn you boost leaks, DAMN YOU
and about the carb cleaner - spray it in through the TB or around the seals (from the outside).
EvoLuTioN
no-JZ Your Mom!
Mar 10, 2006
508
Bed
oh damn i'm having the same problem...just got a DDP and boost controller installed, and can't boost past 2psi, barely accelerating after 20mph...and dont yell, but i'm on unretorqued head (going to the navy in 2 weeks and having it shipped to SP), would be a possible BHG? smoke comes out like a bitch every once inawhile...=( help
ps.. no check engine lights, no coolant leaking/bubbles in coolant
UkiSash
no mor sup :(
Jul 12, 2005
159
Weth CT
Check the IC pipe that goes from turbo to IC, i had the same problem, mine was cracked, as soon as i replaced it everything was fine, boosted just like it should.
