Son drives car,car comes back not much boost.He says egt went higher than normal. 1200-1300 not for long, Comes back down to 800, Limps home. Some up and down play. Buy rebuild kit.saving for rebuilt 57 trim.rebuild went smooth figuring just a bandaid. Fire up with new kit in see blow by coming from everywhere! Much cussing insues. remember that rebuild done before had different bearing. so I do a quick teardown. put correct bearings back in.
The question is if oil moving past bearings is boost pressurizing crank case?
No I haven't had time to leak down or compression test. the only reason I short cut this was MONEY.And I have no faith in this car! fix one thing two new things go bad
