Maybe on cold startup, that's it. Do you think he can get away with an oil that's 0/10W-20? Are you sure there's not something preventing the oil from draining back into the block fast enough?
jdub said:I'm not a big fan of shimming the 7M oil pump that much...the motor was designed with a high volume, low pressure system. I know guys do it, but it can cause problems like this one and it's hard on the pump. Now that it's done, taking the shims out would be a royal PITA.
Personally, I think there are several things that can be done to help this problem without removing the pump.
1) Go to a full flow, thermostat controlled cooler circuit. The longer piping and a remote filter will reduce some of the pressure before it hits the motor.
2) Could install a bypass filter pre oil cooler on this circuit that will bleed off a small amount of oil, filter it, and dump back into the pan before it ever gets to the block. A full flow cooler/remote filter circuit will not use the stock cooler return on the pan...perfect for this. This will reduce some pressure too.
3) Don't use more than a 10W-30 weight oil...I would use a "true syn"
4) Use a -3 turbo oil feed line...if necessary, use a restrictor.
starscream5000 said:All of those involve putting some money into the car, some a lot more then others. Taking out the shims if fee! But like you said, a royal PITA. He may want to refer to the "redneck bearing fix" thread to get a good idea of how big of a PITA it is.
jdub said:In fact, you "could" try this: Remove the relief spring from the oil filter housing and either shorten it or find a weaker spring w/ the same dimensions, or remove some material from the retaining bolt to take some tension off the spring. You will allow more oil to take the cooler circuit back to the pan. Just be careful, you don't want too much diversion.
