turbo question
Waste gate should have tension and you shouldnt be able to move the flapper easily. Shouldnt be massive cracks that you can see through around the flapper.(down pipe side)
Can replace it seperatly than the turbo.
If you had a vacuum leak it would be idling like carp usually.
tyang82
487
Milwaukee
thanks man, i really appreciate the help
Tho that would cause a boost leak bov doesnt have anything to do with building boost. Only releasing it from the pipes when you let off.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Actually, if he's using a stock BPV, and it has failed, it will be open all the time. Open all the time means it's spilling quite a bit of compressed air back into the accordion hose, and it would build boost measurably slower.
